Whirlpool Imperial dryer timer clicking
Dryer stopped working. Light turns on when door is open. The timer/heat select dial makes clicking noise when it is plugged in. When the start button is pushed it does nothing.
This is the first problem we experienced with the washer.
[quote=Frago;21693][COLOR=red]Dryer[/COLOR] stopped working. Light turns on when door is open. The timer/heat select dial makes clicking noise when it is plugged in. When the start button is pushed it does nothing.
This is the first problem we experienced with the [COLOR=red]washer[/COLOR].[/quote]
Frago,
In order to provide most accurate advise we need the complete model number of the washer (or dryer?).
