Whirlpool icemaker in WRS588FlHZ00
Brand:Whirlpool
Model Number: WRS588FIHZ00
Main Symptom:No ice
What happens & when:No ice after 3 months unplugged while on a trip.
Error Code (if any):None
Parts or tests already tried:New icemaker and water control vale
I’m attaching the tech sheet for this model below. If you go into diagnostic mode and run test 44 with the ice bin in place and the door closed, what test result do you get on the display?
service-and-wiring-sheet-w11090558-revC (1).pdf (430.1 KB)
I get a flashing 2 and a Replace filter followed by 23 when doing 44,
Ok, open the doors and take off the toe plate at the bottom. Check the harnesses running up into the left-hand door for any pinched, broken, or damaged wires.
I can’t find any damaged wires or areas where the insulation has been pinched,
At the bottom of the door look for a harness with Tan, Brown, Yellow, Red, Black, and White wires. Disconnect that harness.
On the door-side harness take a continuity reading between White and Yellow wires, and a resistance reading between the Red and Black wires, let me know what readings you get.
Red and Blk, open. Yellow to Whitec 1.2
Ok, that means we’ve either got an open icemaker motor circuit in the door which could be a damaged harness or a bad switch, or the icemaker itself is bad out of the box (this does happen).
Go to where the harness for the icemaker connects to the door and disconnect it. There’s going to be a sleeve covering the wires between the connector and the icemaker, push that back so you can see where the White and Red wires connect to the plug and take a resistance reading on those pins of the icemaker harness. Should be about 35Ω-45Ω.
If that’s good, remove the icemaker On/Off switch and the ice bin rocker switch (if your model has it, some don’t). Check the On/Off switch for continuity in the On position and the rocker switch for continuity with the rocker held down.
If the switches and the icemaker motor are good then the harness inside of the door is bad. This was a known issue and may be covered to some extent by the manufacturer depending on your serial #. If it comes out looking like the harness inside the door is the issue go ahead and send me you serial # so that I can look to see if it might fall under that coverage.
