Ice maker (IM) not working.
Please help me get ice for my wife - she can get pretty grumpy without her ice!!
I have a Whirlpool Conquest (model # GS5SHAXNQ00) of which the ice maker is not working. This is a side-by-side with IM/water in the door below the ice maker. There is an infrared “ice bucket full” sensor.
I checked the IM/Door water valve and it appeared to be malfunctioning on the IM supply solenoid … so i replaced the valve. Switching the valve leads provided water flowing thru the IM fill line but not visa versa - so line is not frozen.
Infrared sensor indicator light seems to be functioning correctly.
When i jumper across T-H the IM does not cycle.
Check voltages over IM N-L = 98 VAC
Chec voltages across black-white wires of incoming plug pins = 99 VAC
I expected to see 120VAC (from what i have read in other posts on this board). What could be the reason for the lower incoming voltage?
Is there anything else i should be checking?
Where does the incoming plug to IM terminate?
Will my wife still be grumpy even after the IM is working? ![]()
