Whirlpool heavy duty thin twin dryer-runs but no heat
I have a Whirlpool heavy duty thin twin dryer
the dryer works…spins,turns…but there is no heat
is it a heating element? how much does it normally cost to fix
if i have the part is it easy to fix yourself?
I live here in tempe az (phoenix)
if there is anyone on this blog that is from the area who would you reccomend to call to get this fixed
thank you
John
Here is your parts breakdown
Replacement parts for WHIRLPOOL LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM | AppliancePartsPros.com
Here is a manual, it should be close to your unit.
Service Manual L-56 Large Capacity Thin Twin Service Manual - ApplianceDigest.com
You will have to join the site to download the manual but it is well worth it.
[COLOR=“DarkRed”]spins,turns…but there is no heat is it a heating element?[/COLOR]
Cannot say, you will have to do more trouble shooting.
[COLOR=“DarkRed”]how much does it normally cost to fix if i have the part is it easy to fix yourself?[/COLOR]
Depends what if anything is needed, see the parts listing for prices.
First thing to check is the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The motor etc. uses half the line while the heating coil requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
Next would be the heater and the thermal fuse.
If the fuse is blown then check/clean your vent system as it is the most common cause of the fuse blowing.
If the vent is OK get back to us as there are other things you should check before replacing it.
is the fuse at the fuse box for the house or is it inside the machine somewhere? i had pulled the machine out and disconnected the silver tube and checked for lint then tried to reach up inside but my hand was too big…is that what you ment for cleaning the vent system
If the vent is OK get back to us as there are other things you should check before replacing it.[LEFT][COLOR=#000000]
Read more: http://forum.appliancepartspros.com/dryer-repair/174079-whirlpool-heavy-duty-thin-twin-dryer-runs-but-no-heat.html#post354911#ixzz1EEIKroek
[/COLOR][/LEFT]
[COLOR=“DarkRed”]is the fuse at the fuse box for the house or is it inside the machine somewhere? [/COLOR]
The fuse (thermal cut-off), I am referring to is Item 15 in Section 4 of the parts.
If you have a fuse box in your house then instead of resetting the circuit breaker, check the fuses. There should be two of them, one for each side of the line.
[COLOR=“DarkRed”]is that what you ment for cleaning the vent system[/COLOR]
Not knowing how your vent system is connected I cannot say.
It must be clear on lint blockages all the way from the dryer to the outside. Also the vent louvers (if you have this type) must be opening.
I see where the fuse (thermal cut-off) is …is it easy to get to?
do i have to take half the machine apart to get to it?
when i get to it…is there a toggle/button i push to reset it?
what does a blown fuse look like?
i had flipped the fuse on/off at the wall and still no heat
You cannot tell if it is blown by looking at it, you need a meter.
Check the manual for how to get at it.
