I just replaced the heating element and dryer still not heating…Could it be one or both of the thermostats? I have a multimeter, but don’t know what the numbers should be when testing.
A model number may help others help you.
Find your model number - AppliancePartsPros.com
On older units it could be a number of things:
Thermal cut-off
Hi-limit thermostat
Cycling thermostat
Timer contacts
Motors heater centrifugal switch
Heating element which you have already replaced. Note that it is not unheard of to receive a bad replacement part.
But first I would check the power.
The motor and drum light work off of half the line (120 volts) but the heater requires both sides of the line (240 volts).
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
