Whirlpool GU1500XTLS3 Blinking Normal Light
I have a Whirlpool GU1500XTLS3 that is about 4 years old. The other day the light on top of the normal button started blinking. I pulled the cover off to check if any of the boards were burnt up and everything appears ok. The dishwasher will not do anything. I think it may be the control panel that needs to be replaced. Anyone have any suggestions?
Could not find info on the given Model Number. The following is for a XTLS3 not a XLTS3
Replacement parts for WHIRLPOOL GU1500XTLS3 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
A single blinking light is often a stuck key. The tech sheet shows how to check this.
denman, thanks for the help. I checked the diagnostic sequence (high temp, air dry, high temp, air dry) and it did not do anything. The parts link you referenced has a lot of parts. Do I need all of those or just the Panel Cntl? How hard is it to install for a do-it-yourselfer? If I replace this part and it doesn’t work can I return it? I don’t want to spend $200 on a repair man when a new dishwasher is about $500. Thanks Again!!!
[COLOR=Blue]I checked the diagnostic sequence (high temp, air dry, high temp, air dry) and it did not do anything. [/COLOR]
Yes I figured that would be a long shot but worth a try.
[COLOR=Blue]Do I need all of those or just the Panel Cntl?[/COLOR]
The way this is troubleshot is to check the keypad with meter as shown bottom middle of the first page. This can confirm that you have a stuck key in which case Item 1 Panel cntl needs replacing.
If all the keys check out OK the Item 11 Electronics Control Assembly is the most likely culprit. Still a bit of a crap shoot but your odds are better
[COLOR=Blue]
How hard is it to install for a do-it-yourselfer?[/COLOR]
Not difficult just take your time taking it apart make notes on anything you feel you may forget. Also the following should help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
[COLOR=Blue]If I replace this part and it doesn’t work can I return it?[/COLOR]
No usually if you order electronic parts you own them.
