Replacement parts for WHIRLPOOL GX2SHBXVY00 REFRIGERATOR | AppliancePartsPros.com
See the attachment for a tech sheet.
[COLOR=“DarkRed”]
Yesterday, it froze again. This time the condenser was very clean.[/COLOR]
Dirty condenser coils will not cause the evaporator to ice up.
[COLOR=“DarkRed”]Is it possible that this is a bad disposition of my food in the freezer that prevents proper air circulation? I saw that there was a component of the internal duct of refrigerant. I think this is a thermistor to allow defrost[/COLOR]
Since the unit ran good after a manual defrost I would say you do not have a circulation or a thermistor problem.
If it was circulation the food in the bottom of the unit would freeze and/or food at the top would be too warm.
If it was a thermistor problem then the temperatures would not be correct after the manual defrost.
The compressor would cycle on and off because it thinks the freezer is at the correct temperature when in reality it is to warm.
[COLOR=“DarkRed”]
It is this component that distributes electricity to the defrost element.[/COLOR]
No, the thermistor just tell the control board what the freezer temperature is.
[COLOR=“DarkRed”]Is this element is fed 24 volts AC or not? Yesterday when I was testing, I had 24 volts AC and I was frozen.[/COLOR]
The heater runs off of 120 volts.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle see the tech sheet. When the fans and compressor turn off, you are in defrost.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the control board (jazz pcb) needs replacing, re: it is probably never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 10 in Section 8) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 14 in Section 8) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the control board toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
GX2SHB.pdf (425.8 KB)
