The dryer all of a sudden stopped heating or tumbling. The only way it would stay is to keep start button pressed but no heat. The fuses check out fine and it’s thought that maybe the circuit board needs replaced, just a thought. We don’t know what else it could be since the thermostat doesn’t control whether the unit stays on or not.![]()
you need to replace the control board. the part # is w10110467 tom
