Whirlpool gold double oven
Need help please!
I was using the cleaning cycle and now the oven will start to heat and after a minute it stops and displays F5 E1
Any Suggestions?
I already turned the breaker off overnight.
Parts for Whirlpool GBD277PDB09 Wall Oven - AppliancePartsPros.com
Check the door latch switches.
Check the wiring from the control board to the latch switches.
If all OK then odds are it is a control board problem.
GBD277.pdf (504.1 KB)
