My Whirlpool Gold Accubake oven control panel has recently been having difficulty. For the past few months the buttons don’t always work, but I have learned that if I lift up on the panel slighly, the buttons will work. More recently the control panel has been displaying the error code E0 -F2- and has begun beeping. When I unplugged it tonight and plugged it back in the error code was gone (for now anyway). What does this error code mean, and what should I do to fix the oven?
Cannot find any info on the given Model Number.
I think it is a Q1 not an O1, following info is for a Q1
Replacement parts for WHIRLPOOL GY395LXGQ1 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%209752914.pdf
Here is a service manual
Looks like a shorted key. You may want to try the following though usually it only repairs open keys/contacts. Often you troubleshoot this by checking the keypad with a meter, if OK then you assume it is the control board. Unforetunately I cannot find the keypad pinout diagram for this unit so cannot confirm a keypad problem. Though it would be my choice to replace if necessary.
A bit of a crap shoot!!!
Ribbon Cable Cleaning
Unplug the unit
Open it up
Clean the edge connector.
