Does your part AP3882915 control the defrost cycle? If not which part does? Thanks for your reply.
Parts for Whirlpool GD5RHAXSS00 Refrigerator - AppliancePartsPros.com
[COLOR=“Blue”]
Does your part AP3882915 control the defrost cycle?[/COLOR]
No this is just the user intrface
[COLOR=“Blue”] If not which part does?[/COLOR]
The main control board (item 18 in the Unit Parts section) (AP4334025)
You did not say exactly what the problem or symptoms were.
A defrost problem can be the board, the heater or the defrost thermostat.
GD5RH.pdf (695.5 KB)
