Whirlpool GD25DIXHS02 REMOVING CONTROL BOX
I have a Conquest unit. I think the defrost timer or relay is bad. I need to get inside the control box to check it. I removed the two hex screws that hold it, but it will not come off. It pivots to the front( the back is loose, but I do not want to force anything. Can anyone help explain the “trick” to getting this off. Thanks. My frig is up to 65,now!
If case someone can help, I will provide more info on the problem. This frig for the past two years or so has had a problem with water pooling in front of the unit. I found that the defrost water line was getting plugged with ice. I would shut the unit off and use a hairdryer and hot water to unplug it. Over the past week I have noticed the frig getting warmer and the freezer is not as cold. I see that there is thick frost on the entire pack of the freezer compartment.
THANK!
Replacement parts for WHIRLPOOL GD25DIXHS02 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202198693.pdf
You may not have to get at the defrost timer.
See in the tech sheet on how to force a defrost cycle.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle see the tech sheet.
When the fans and compressor turn off, you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
We I got the box cover off, but do not see how to "adjust the timer.
I have an ohm meter. It is not easy to get to the back of the unit. I touched the ohm leads to insure it registers resistance. When I disconnect one side and try to get a reading, I get none. Is ther eanother way to check the heater element before removing it. IT seems liek it woul dnot be an item that would fail.
It is an electronic timer, you cannot adjust it.
It monitors the number of times the door is opened and then adjusts the defrost cycle frequency to this.
To force a defrost cycle use the procedure in the tech sheet.
Just thought of something. If the heater coil is the issue can I remove it and check it by just running 120 v through it to see if it heats?
yse, I did this and it does not work. I checked the ohms on the heater and it does not appear to have any resistance.
[COLOR=“Blue”]yse, I did this and it does not work.[/COLOR]
Strange that you could not force a defrost cycle.
This may indicate that the defrost timer is also shot but I would change the defrost element first.
[COLOR=“Blue”]and it does not appear to have any resistance.[/COLOR]
Just to clarify as some people say it has no resistance when there meter reads a zero. When in reality the meter is just on too high of a scale and the device is OK
So if you are reading infinite resistance (an open) then the heater is toast.
I would also check the defrost thermostat, it should be 0 ohms when frozen.
Also if it looks bulged out I would replace it as water has gotten into it and it will fail in the near future.
NOt sure if you saw my reply to this. I wanted to hear back befreo disassembling the coil. Can you get it out form behind the cooling refrig coils without to much difficulty?
[quote=denman;165632]It is an electronic timer, you cannot adjust it.
To force a defrost cycle use the procedure in the tech sheet.[/quote]
Thanks, I will take out the element first and double check the resistance. I cleaned the ice from everything and plugged the frig back in and it gets cold, so I know I have the correct general problem area identified.
I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. Is the defrost thermosat the bimetl-def.
I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.
P.S. I tested it again and the test worked as before. I also could hear the one “click” from the relay.
[COLOR=“Blue”]I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. [/COLOR]
OK if I follow along you did not unplug anything in the evaporator coil area so I think you have it beat.
[COLOR=“Blue”]
Is the defrost thermosat the bimetl-def.[/COLOR]
Yes
[COLOR=“Blue”]I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.[/COLOR]
Yes
I think you have found the problem as you can force the defrost heater on but the timer will not automatically do a defrost. The timer section of it is not working.
Nothing is 100% guaranteed but I would replace the timer.
HI,
I am going through the same problem. The tech sheet link does not work - can somebody repost that?
[quote=denman;166150][COLOR=blue]I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. [/COLOR]
[COLOR=blue]Is the defrost thermosat the bimetl-def.[/COLOR]
Yes
[COLOR=blue]I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.[/COLOR]
Yes
Nothing is 100% guaranteed but I would replace the timer.[/quote]
Please see the attachment
GD25DI.pdf (166.5 KB)
