Brand: Whirlpool
Model Number: GC5SHEXNQ05
Main Symptom: Freezer fan not working, Fridge not cooling
Parts or tests already tried: Inverter
My side by side stopped working properly last week. It has a variable speed compressor (Embraco VEGY 7H) and inverter. For some months, we’ve been hearing what sounded like the compressor being turned on and off in short cycles but the unit seemed to be working ok - kept temperature and no other issues. Last week I discovered that the top part of the freezer had thawed out and the fridge was no longer cool. Took everything out of the fridge & freezer and ran it empty to try and find out what was happening. When plugging the unit back in, I hear a high pitch noise and then after a few seconds a click, the condenser fan and the compressor run, power to the fridge & freezer interior, the evaporator fan runs and the evaporator coils start to cool. After a few seconds the high pitch noise stops, both fans and compressor stop (power still on in unit). The high pitch noise starts again and turns everything on again. This start/stop continues for up to 12 cycles then the high pitch noise stops and the condenser fan and the compressor run (no odd sounds when running) and fridge & freezer initially start to cool. At some point the evaporator fan stops (so no cold air going into fridge) and the freezer continues to get cold.
I replaced the inverter board thinking the inverter was the cause of the short cycling. I’m now not getting the short cycling as before, but it didn’t solve the cooling problem.
When I plug the unit in, the evaporator fan runs for a short while and cold air gets through to the fridge and both freezer & fridge start to cool. Evaporator fan stops at some point, whilst the evaporator coils continue to get cold and within a couple of hours a thick frost is on the coils. Compressor and condenser fan run continuously - compressor getting very hot.
Could the fault be the defrost thermostat or is it something more (problem with refrigerant/closed system?) How do I test to find the source of the problem?
