Whirlpool Gas Steam Dryer Metal Door Clip
How Do You Take Clip Out Of Door To Replace
[quote=THE BREAKER;345177]How Do You Take Clip Out Of Door To Replace[/quote] Any help would be appreciated. The part number is 24 [COLOR=#0066cc]AP4364920[/COLOR] it is a catch for number 9
If you are talking about the door strike (#9 on the diagram) then it’s just screws in. If this is some different part, then refer to the diagram numbers.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WGD6600VU1 29`` GAS DRYER | AppliancePartsPros.com
the part # is 24 [COLOR=#0066cc]AP4364920[/COLOR] it is a catch it hooks into #9 .Do I have to take the door apart to get this part outor does it pry out.
Using a flat blade screwdriver, pry it off on any side of it.
Gene,Thank you I will try it this weekend I didnt want to force it if that wasnt how to do it
