Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
We have a front-loading Whirlpool washer that sits in our closet with a dryer stacked on top. Initially, our washer wasn’t going into spin mode, so when the cycle completed, our clothes would be dripping wet. We ran the diagnostics test as well, and it didn’t come up with any error codes, and the spin cycle worked in the diagnostic mode. We read on a lot of websites that when this happens it may be a door lock switch problem that causes it to skip the spin cycle. We also read that an imbalance can cause this, and our stackable set is on wood floors.
We pulled out the washer from the closet and attempted to check the hoses and empty them. We put everything back in, and ran the washer. This time, the spin cycle did start…?! Not sure why. But, it seems like the washer is still having some problems with draining, as it seems to sit in that cycle for an extended period of time - meaning that the clock on the front of the washer says it will be done in 45 minutes, but it ends up taking about a total of 65 minutes. It seems like it spends a lot of time draining, and a very short time in spin.
Then, today, the washer stopped spinning again (still works in diagnostic mode).
We did clean the pump filter. The only thing in it was a penny. We are using HE detergent, and a very little amount per wash. We’ve checked the filter, drain hose, stand pipe, and ECO valve (under the drum) and found no blockages. There were no blockages in the drain motor that we could see (however I did not disassemble the rectangular part in the rear behind the drain hose).
When running an empty load on a Rinse/Drain cycle, the water in the barrel drains very quickly, within 20 seconds, but the washer then continues to try to pump out water for the next 8 minutes (even though there is no visible water in the drum) as the drum agitates in alternating directions as if it is trying to “re-balance” the empty load. The pump is powerful enough to cause the empty drain hose to jerk about behind the washer. Eventually
it gives up and moves on; skipping the high-speed spin.
Any ideas? Thanks in advance!
Remove the top panel and locate the pressure switch (#5 at the diagram). Dosconnect the hose from the pressure switch and blow some air trhough the hose to make sure it is clean.
Reconnect the hose and give it a try. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER | AppliancePartsPros.com
