When gets to rinse cycle, stops . Letters F H flashed . Help needed
What is the complete model number of the washer?
Where can I found the model number?
Usually it’s on the door frame.
Model # Ghw9150pwo
Remove the bottom access panel and clean the pump filter.
Check the pressure switch as described in the attached file.
Here are the breakdown diagrams and Parts for Whirlpool GHW9150PW0 Washer - AppliancePartsPros.com
Testing pressure switch.pdf (130.9 KB)
