My wash has done this before it comes up error F21 and I know it means the pump is clogged…So how do i take the front cover off and clean out the pump
Remove the three torq screws under the front kick panel and twist off the cover of the pump. Use a shallow container to hold the water.
THANK YOU SO MUCH!
