Whirlpool Front Load Dryer Not Turning
Electric sounds are made when activating dryer but barrel does not turn. Dryer relatively new (3 yrs). Any suggestions? Is there are trouble shooring list I can go thru? Mike
Mike,
If the motor works but the drum does not turn, most likely the problem is a broken belt.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER8648PW0 29"electric Dryer | AppliancePartsPros.com
Thx Gene. Barrel has tension on it so I think belt is intact. Could the motor be fried ? If so, is it better to have service call? And who is best to call. Bought unit at Lowe’s and no warranty left. Mike
Mike,
Open the door. While pushing and holding the door switch, push the start switch and the same time turn the drum manually. Post the results.
