Brand: Whirlpool
Model Number:WRT541SZDM01
Main Symptom: Compressor and fans run continuously. Defrost heater failed. Related?
Brand: Whirlpool
If the defrost heater has failed then this would certainly cause the compressor and fans to run continuously. A defrost problem causes the evaporator to ice over and will cause the unit to have to run longer trying to get the unit down to temperature.
