Whirlpool Fridge Water Dispenser Leaking
My Whirlpool Fridge Model gs6shaxmb00 is leaking from the water dispenser. It stared out and a very slow leak but now it is very fast. What part would I need to replace?
I would start with checking the water inlet valve behind the fridge. Disconnect the water line that goes to the dispenser and see if it leaks before and after trying the water dispenser.
