Whirlpool Fridge ice maker fills again causing overfill
Brand: Whirlpool
Model Number: WRF736SDAM12
Main Symptom: Ice maker fills a second time causing water to leak into ice bin.
What happens & when: Ice maker will fill with water after a batch is completed but then like 10 minutes later, fill a second time. This causes water to overflow the already filled tray and leak into ice bin. Otherwise it works normally, no errors etc and sometimes doesn’t happen at all. Could this be the control board or does something else initiate another fill cycle?
Thanks!
Error Code (if any): None
Parts or tests already tried: None
It sounds like the main control has an intermittent glitch. The main control is responsible for identifying when a harvest needs to happen and when to fill the ice maker. https://www.appliancepartspros.com/whirlpool-cntrl-elec-wpw10589838-ap6023259.html
Thanks for quick reply!!
