Fridge will run until it gets to proper temperature in fridge and freezer then it will cut off. The problem is both sides get warm and it won’t come back on. I can usually get it to start by turning temp control colder. Then again after getting cold enough it cuts off and won’t come back on again. I cleaned coils. When running it sounds okay and cools very quickly. My guess is the thermostat? Or possibly compressor relay?
Seems like a bad cold control AP3037004
Thanks for the info! I ordered the cold control and it arrived overnight!
I just installed it and I have a question. When you push the thermostat through the tube should the tip be exposed at the end or is it okay to be inside end of tube?
Thank You
As long as you put the control sensing wire near where it was before, you should be ok.
Fridge is back to normal now. Thanks for your help. Great website!
