Whirlpool Upright Freezer, Model # WZF34X16DW
Greetings. I purchased this new freezer in December 2016. Within a week, I started hearing a loud buzzing coming from the back when the freezer was running. When I pulled off the cardboard cover from the lower back, I noticed the sound was coming from two copper pieces touching and vibrating as the compressor was running. The two pieces are located to the right of the compressor, consisting of a thicker horizontal copper tube coming out of the right side of compressor, and a thin vertical spiral tube coming out of the bottom end of a fat vertical cigar shaped copper tube (I believe it is the UV Dye Dryer), which sit just behind the right hand grill openings on the cardboard backing. The spiral tubing was touching the compressor tubing, vibrating, and making a loud noise. I also noticed that a square piece of gray putty like material (with plastic backing), about 2" x 2", was laying on the metal bottom of the freezer unattached to anything, laying just under these tubes. Part of the putty square was disrupted and looked like it had been wrapped around something. In holding it up, it seemed to be about the size to wrap and stick around half of the fat cigar shaped vertical copper tube (dryer), with the remainder of the putty square being long enough to go between the two pieces of copper tubing that were touching (the putty side touching the spiral tubing, and the plastic backing side touching the compressor tubing). Can you please confirm what that putty square is for, if that is where it goes, and how to properly reattach it, if possible? Should those tubes be touching? Does this need to already be fixed under warranty after only a week? Thanks for your advice!
