I was using my stove one day and suddenly the all burners stopped working. The oven also stopped working. I checked the breakers and power is not problem. When I turn burner knobs the LCD screen/control selector lights up and allows me to choose functions (bake, temperature, clock, etc), but stove AND/OR oven does not come on. I am a female with little attitude for repairing appliances without instructions.
Any help with troubleshooting this problem is appreciated.
A model number may help others help you.
Find your model number - AppliancePartsPros.com
If this is an electric stove then a power problem is at te top of the list as possible causes.
The oven light and control board/timer uses half the line (120 volts) but the elements all require the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
