Whirlpool fault code E6 F2
Gene,
I too am having the E6 F2 error message on a Whirlpool Double Oven (MOD RBD305PDB8) in my rental property.
As I read in this thread I turned off the breaker, removed the control panel, unplugged the ribbon cable, reinstalled control panel (with cable still unplugged) and turned the breaker back on.
This resulted an F2-E1 error (which I think is expected). Sometime overnight it reverted back to the E6-F2 error.
From reading this thread it appears that this means the control board is likely bad. Is that correct? Is the control board replacement something the average DIYer can do without any special tools?
Thanks!
Yes, sounds like the control board has gone bad. This part is not too difficult to replace yourself. You can find the instructions in this thread as well.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RBD305PDB8 | AppliancePartsPros.com
I also have double Whirlpool Oven model GBD307PDS7 with F2 E6 code. I checked and cleaned the ribbon still same problem. I also checked for continuity on low voltage transformer and that was ok. I checked for 120VAC between P16-5 and P16-7 and that was ok. Not sure what else I can check. Should I replace the panel or the board? I did notice that there is some discoloration around a couple of the components towards the top of the board unit and one of the components towards the right side of the board. Thanks.
[quote=Gene;2589]…Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly)…[/quote]
Have you ran this test? What was the result?
Here are the breakdown diagrams and replacement parts for the Whirlpool oven [MODEL]GBD307PDS7[/MODEL]
[quote=Gene;2589]Hi Shawn
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
Good luck.
Gene.[/quote]
Hi, Gene,
I have a problem you’ve addressed with my Whirlpool ovens (RDB305PDS14). The E6 F2 error code and beeps occurred. I saw in one of your posts to disconnect the ribbon, then turn on the power again. My problem is that the code that then did appear was now E1 F2. Not sure which of the two recommended parts to replace applies, as the error code changed. Help? !
Thanks so much.
karen
Karen,
The “F2-E1” error code means the control senses that the key pad is not connected to the control board which is normal because you had disconnected it.
The problem most likely is a bad control panel. If you need the correct part number then post the color of it.
[quote=Gene;138420]Karen,
Gene.[/quote]
Wow! Thanks so much for responding, Gene. My ovens have a black control panel with stainless fronts. (Model #RBD305PDS14) So, maybe AP3131744?
Anything in particular to watch for when installing?
Thanks so much for your expertise!
karen
Hi Karen,
The AP6012603
is the correct part number. Be careful with the ribbon cable. Good luck.
[quote=Gene;139023]Hi Karen,
The AP6012603
Gene.[/quote]
Thanks again for your response. You know, it’s funny, when I first took the control panel off, the ribbon cable seemed to be disconnected from the clip that holds it in place. I reconnected it, which did nothing, but how odd, seing that it had been working fine, and no one had ever been inside before. Oh well, I’ve ordered the part. Hopefully I can install properly without any drama!
Thanks again!
karen
You are welcome. Good luck and keep us posted.
[quote=Gene;139233]You are welcome. Good luck and keep us posted.
Gene.[/quote]
Hi, Gene,
Received the control panel today, installed, being particularly careful with the ribbon. When I reset the breaker, that familiar series of beeps sounded, with no display appearing for about an hour now. Do I need to be patient, or should something have occurred by now?
Thanks,
Karen
[quote=kayna222;139438]Hi, Gene,
Thanks,
Karen[/quote]
Rats. Another series of beeps-- still no display.
karen
[quote]…series of beeps sounded, with no display appearing for about an hour now…[/quote]Hi Karen,
Sorry for the delay. Sounds like this is a new and different problem.
Check the low voltage transformer (#5 on the diagram) plug connection to the control board. Check for continuity across the blue and red wires.
If there is nothing wrong then looks like the control board has gone bad.
[SIZE=3][COLOR=#000000][FONT=Calibri]Thanks in advance for those that post their experiences and the experts (Gene in particular) who post great advice.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Same experience as many others in this thread. 3 yr old Whirlpool oven GBD307PRS01 (Stainless) with the E6 F2 error code and symptoms many others describe.[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]My model: Control panel parts replacement parts for WHIRLPOOL GBD307PRS01 30" Built - in Electric Double Oven Convection - Upper Self - Clean (gold Line) | AppliancePartsPros.com[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Can someone clarify how to remove the control panel to begin the diagnostics? [/FONT][/COLOR][/SIZE][SIZE=3][COLOR=#000000][FONT=Calibri]Here are the steps I have gathered from this thread and others:[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]1. Remove the screw holding the each side trim. (DONE)[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]2. Remove both side trims by pulling them from the bottom toward yourself and down to release from the control panel tabs. (DONE)[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]3. Remove the screw on each side of the control panel. (No side screws, only four screws along bottom of control panel in the vented area, which I removed)[/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]4. Pull the bottom of the control panel toward yourself and upward to release it from the side tabs. (Nervous about this step, doesn’t budge and I’m not clear on the location of the side tabs)[/FONT][/COLOR][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]Any thoughts out there? Thanks everyone.[/COLOR][/SIZE][/FONT]
Try to use the instructions from the following Service manual.
Hey Gene!!
I am looking for where to purchase the control panel part number you post at the beginning of this thread. Any idea on where to find it???
thanks so much!
[quote=caryn;157561]Hey Gene!!
thanks so much![/quote]
Sorry for the broken link. It’s fixed there and it’s here as well.
AP6012612
thanks, Gene, for the super quick response. We have a black double over, model number RBD275PDB12. Much like several of the folks on this site, it beeps strangely, then shows the E6 F2 code. We used to be able to clear it off and then cook, but now the oven has stopped working completely. I opened the control panel to expose the control board and there were two small “cylinders” on the board which were extremely hot to the touch. I dont know if that indicates the problem is with the board (and not the panel)?
I guess my question is, with this code, do you think the problem is the board or the panel? I am trying to figure out which to replace?
Thanks so much for your help!
Try to unplug the control panel ribbon cable from the control board, turn the power back on and watch it for a few hours. Post the results.
hey Gene, we tried that a couple days ago. I think something in your post talked about it. The “weird” thing about our oven is it is hard wired to the house and doesnt go through a breaker box. So we cant do anything about the power (or turning it off). not sure if that is weird or normal?
(by the way, I think its fantastic how you help folks find the right parts for their oven!)
