Whirlpool F3
My Whirlpool oven often displays F3, beeps loudly and turns off. Sometimes it will shut down without the F3 and beeping. Checking the error codes on the internet led me to believe I needed a new oven sensor. I replaced the oven sensor and still have the same problem.
Replacement parts for WHIRLPOOL RS385PXEB0 | AppliancePartsPros.com
I would check the oven sensor with a mter, just to ensure you do not have a defective sensor.
http://www.applianceaid.com/elecrange.html
See Items 7, 8, 20 and 21.
If OK.
Disconnect it from the clock (control board) and check it from that end, to make sure you do not have a bad wiring harness,
If OK
Check that the connector on the clock is clean.
Remove the clock and check for a bad connection or cold solder joint on the board.
Cold solder joints are often a duller gray and/or have pinholes.
Also wiggle the components to see if the the component legs on the solder side of the board move.
If all OK then your clock is toast, unfortunately it looks to be obsolete.
There are companies that fix boards, Google " appliance timer repair".
RS385.pdf (632.0 KB)
