Whirlpool Estate Electric Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them…then went to use again and it would not turn on at al. They dryer was still hot to touch…even after it had not been running for over an hour…I walked away and next morning it was still HOTTTT, I have now unplugged it. What could this be?
I cannot find any info on the given model number, please check it.
Your heat problem sounds like a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run all the time.
Most units have a thermal fuse, perhaps this has blown and that is why it will not start.
Check in the control console or on the back of the unit for the wiring diagram.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
The model # is TEDS740PQ0…
[quote=denman;465586]I cannot find any info on the given model number, please check it.
There is a good STICKY at the start of this forum about it’s use.[/quote]
Replacement parts for WHIRLPOOL TEDS740PQ0 29"ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram
Wiring Sheet - 8528187.pdf (332.8 KB)
