I’m trying to determine what part I would need to replace on a Whirlpool Estate dryer that will not heat. Also, after determining the part I need, how much technical expertise is needed to replace the part? Are the instructions fairly basic?
No heat can be a number of things: power, heating coil blown, open thermostat/thermal cut-off, timer contacts or the motors centrifugal switch.
I listed them in the order they should be checked.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The motor etc run off of 120 volts but the heating coil requires 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
The heating coil, thermostats, high limit cut-off and the timer contacts can be checked with the unit unplugged using ohms. This is much safer than messing with the unit plugged in.
If the thermal cut-off is blown get back to us as there are other things that should be checked before replacing it.
Cannot really say how much technical expertise is required.
Also there are lots of videos on Yahoo.
Your unit is made by Whirlpool.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
There is a good STICKY at the start of this forum about it’s use. LER4634.pdf (125.0 KB)
