Whirlpool Electric Stove Doesn't Work Now
I have a Whirlpool electric stove that has a self cleaning mode on it. we used that mode and the stove top worked for one day and now the stove top and oven do not work at all. the stove has power as the clock still works but no heating anywhere on the stove. what do we need to do???
A Model Number may help others help you.
First I would check is the power to the unit to be sure you have 240 volts. Best way is with a meter.
Try shutting the breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker so depending which side drops out yuo can still have the times but no heat on any element.
