My Whirlpool Dryer (Mod # LER6634DW0) will not heat. I have performed the suggested continuity checks (always removing one connection from each device when it was tested) with the following results. Note: all other functions seem to operate normally except that for the last few months the “start button” doesn’t have to be pushed to start the machine. We have just been using the rotary timer to activate & turn off the machine.
240V shows up on terminal strip where power cord enters machine
With machine running, there is no voltage to terminals of heater coil.
Thermostat, internal bias (3387134) shows continuity between “far terminals” but NO CONTINUITY between opposite terminals that are close together. I tried tying these two together to see what would happen … the heater still did not activate.
There was a lot of lint buildup near the blower wheel when I took off the lint chute assembly, but that is now 100% clean and the blower wheel seems to be working fine.
Any ideas?
BTW, I do not have a circuit diagram for this unit. Is there one online?
[COLOR=“DarkRed”]7. Thermostat, internal bias (3387134) shows continuity between “far terminals” but NO CONTINUITY between opposite terminals that are close together. I tried tying these two together to see what would happen … the heater still did not activate.[/COLOR]
If you have not done so remove the short between the connectors ASAP!!!
A dead short will probably blow something if you put the unit into a low heat setting.
this set of contacts are an internal heater. It is turned on for lower temperature settings and adds heat to the thermostat which causes it to cycle more often which results in a lower unit heat output.
I would start by finding out why the start button does not have to be pressed.
Check that the push to start switch contacts are open when it is not activated.
For the no heat.
Unplug the unit and set it to mid cycle, then check the Timer Switch 2 contacts. They should be closed. LER4634.pdf (125.0 KB)
Thanks for the input and the circuit diagram. I only shorted the leads for a 15 sec test. The heater never activated so I disconnected them and put them back where they came from.
I will check the start switch, but even if the contacts are always closed (meaning “start” is always commanded) wouldn’t that allow the heater to operate? I’m asking because, while I’d like the start switch to work, that is not my #1 problem … #1 is getting the heater to activate.
I will check the timer switch as you recommend and will report back.
Yes it would but my idea is that perhaps by using the timer as the on/off you have caused a problem in the timer.
It looks like you have checked most things in the heater circuit.
The centrifugal switch on the motor may not be closing. It ensures that there is air flow before the heater turns on but is a pain to check.
There is a round about way to check the centrifugal switch.
Since you have checked the heater and the 240 volts, you could put the unit into an auto cycle and let it run. If the timer advances then you know the switch is OK.
In auto modes the timer gets power through the centrifugal switch and the heating coil when it is off. The resistor drops the 240 volts down to 120 for the timer motor.
Before scrapping it check that the centrifugal mechanism is not clogged solid with lint preventing it from actuating the switches. This is a long shot as the motor will usually overheat if the start winding (by the other centrifugal switch )is not switched out after the motor starts.
With the timer set to time dry, you should have continuity from Line 1 to the red wire on the back of the timer. (timer switch 2)
If not, a contact is probably burnt off inside. Sometimes I just take them loose and shake them. If you here something rattling around inside the timer, its toast.
Thanks for the tip. With the dryer operating and in Timed Drying mode (as suggested), I got the following voltage readings between the Timer’s Red lead and the three input leads:
Left input lead (Black wire - L1?): 240 volts
Middle input lead: 120 volts
Right input lead (Red wire - L2?): 0 volts
I’m not an electrician so I was reluctant to use my ohm meter, but its a cheapie so I put it on x1K and measured the resistance from the timer’s red lead to the right input lead (the one showing 0V above) and it showed continuity (0 Ohms).
BTW, one last fact (not previously mentioned): The two sides of the heater coil show 0 voltage between them BUT both do show 120V to ground.
Also BTW (but probably unimportant), the Start switch is now operating normally. All this fussing around must have “fixed” it!
If all of this cements a diagnosis, I would appreciate your conclusion. I promise not to draw this out any further!
[COLOR=“DarkRed”]Left input lead (Black wire - L1?): 240 volts
Right input lead (Red wire - L2?): 0 volts[/COLOR]
The above looks OK to me.
[COLOR=“DarkRed”]I’m not an electrician[/COLOR]
FYI: here is what your power in is:
the middle connector: is Neutral/ground (0 volts)
the left and right: are power L1 and L2 (120 volts).
When referenced to Neutral they are 120 volts but they are 180 degrees out of phase. So when one is at 120 volts positive, the other is at 120 volts negative and therefore if you measure L1 to L2 you get 240 volts. This is what runs your heating coil.
Wattage is voltage times current (amps) so if we can double the voltage we can half the current to get the same wattage out. With half the current we can use a smaller wire size which is cheaper so it all comes down to economics all the way back to the power companies transformer.
[COLOR=“DarkRed”]so I was reluctant to use my ohm meter, but its a cheapie so I put it on x1K and measured the resistance from the timer’s red lead to the right input lead (the one showing 0V above) and it showed continuity (0 Ohms).[/COLOR]
If they both had a red wire on them then I think that would have been timer switch 2 and it is closed as it should be whenthe timer is in a dry mode. I cannot confirm this as the timer in the parts breakdown does not show the back of it.
[COLOR=“DarkRed”]BTW, one last fact (not previously mentioned): The two sides of the heater coil show 0 voltage between them BUT both do show 120V to ground.[/COLOR]
This would be normal. If timer switch 2 is closed then you will see the L1 voltage all along the heater circuit all the way to the right hand side of the heater. You see 0 volts across it because the centrifugal switch 1M/2M is open.
[COLOR=“DarkRed”]
Also BTW (but probably unimportant), the Start switch is now operating normally. All this fussing around must have “fixed” it![/COLOR]
Cannot explain this sounds like it is messing with you.
[COLOR=“DarkRed”]If all of this cements a diagnosis, I would appreciate your conclusion. I promise not to draw this out any further![/COLOR]
Do not worry about drawing this out I volunteer here in order to help people as long as you are willing to put in the time I do not mind continuing. I help you, you help someone else and the world is a better place.
My conclusion is that the centrifugal switch is not closing. You can confirm this by unplugging the unit, removing the wires (they should be the heavier gauge red wires) from the motor’s switch and shorting them together. Tape them so they cannot short to anything else and also that they will not get caught up in any thing when the unit starts up. Then plug it in and give it a try. If you now have heat you know that the switch or it’s activating mechanism is toast and unfortunately the unit needs a new motor.
OK! We have the problem isolated – sort of.:rolleyes:
I pulled the wiring harness connector off to get access to the two red wires you wanted me to short … Lo and behold, the plastic connector where the bottom heavy red wire connects to the motor is all black/burnt. My guess is that the connection became resistive and the high current created heat until the connection was lost. IF (big IF) all I need to do is pull out the red wire, clean it up and buy a new connector (3395683) I have a $3 fix. Unfortunately I don’t know if the connection on the motor side is OK or if the centrifugal switch is faulty also. I didn’t actually short the two to test it, but the black connector terminal is 99% proof that this is where the problem lies. I think I’ll clean up the connector and re-insert it. If I get heat, I will just order the connector.
OK, cleaned up the red wire connector & reinserted the harness at the motor, but still no heat. That tells be the contact on the motor side needs attention with likely motor & (possibly) wire harness replacement.
It’s been interesting, but I’m calling it a day. Big box store here I come.
THANK you for your help. I learned a lot about trouble shooting these machines. I will keep your site book-marked and will refer friends.
I have a LER8620PG0 and I can’t figure out what’s wrong with it at all. For some reason the person who I got it from unhooked all the wires everywhere. I have no idea how to read the wiring diagram! I have two dryers sitting in my basement and not a clue as to how to hook the wires up.:mad:
I cannot really help with “I have no idea how to read the wiring diagram!”.
I have been doing it for years so it is like second nature.
All you do is trace the wires using the wiring diagram and color codes connecting them where they should be connected.
Sometimes using color pencils on the diagram can help.
Perhaps you have a friend who can walk you through it.
Once you get the hang of it, it is fairly easy. LER8620.pdf (251.5 KB)
