Okay.. Before I get started let me say this overheating issue is NOT due to a clogged vent or anything to do with airflow as I have completely dissaembled this POS and it’s spotless, so is the duct. Airflow out the back of the dryer is very high.
With that said, wife informed me dryer will not start.. hit the start switch..zippo. Check voltage at termnial block = 244, all is good there. Find the thermal fuse is blown so I replace it with a equally rated thermistor just in case the problem is deeper, this way once it cools off it will be okay as opposed to dealing a blown fuse again.
Get the dryer started and all is well for about 4 minutes. I can feel the front door of the dryer getting unusually hot and then the thermistor opens and the dryer shuts off. Take er back apart and check:
- Operating thermostat, across reds = 0 ohms, across purples = 7K ohms
- Thermal Cutoff = 0 ohms
- Thermostat = 0 ohms
- Across terminals on the heating element = 9.6 Ohms. Also check to see if the heating element is grounded and its not, terminal to case = OL. Take apart element housing to inspect and it all looks fine.
- Note all ohm readings I have posted are with dryer cooled to room temp.
Reassemble everything and it will run for ever on the air fluff mode, however when on timed drying it gets hot and dies in about 4 minutes with the exterior of the dryer getting way warmer than normal. It seems that the heating element is staying on longer than it should which would leads me to think the operating thermostat is bad but it checks out okay. Guy at local part store is knowledable and he suggests motor is faulty. This does not seem logical to me because it will run on air fluff mode without a hitch and the fact the dryer exterior gets hot suggests that the issue is with the heating element.
I have run out of ideas here so any suggestions are greatly appreciated!
Gary
