The ice becomes massive blocks, which the unit can’t easily dispense. Water is leaking from the maker (see videos). I’m not sure if it’s the tray or the control part that I should be replacing.
Benash,
For this issue, if you remove the icemaker, you will most likely notice that the coating on the icemaker mold is probably deteriorating. The best action is to replace the icemaker for the unit. WPW10190965 Icemaker | Genuine Whirlpool OEM In Stock
