After searching I still need help. Our Duet washer is giving us three beeps at random times while washing. Does not matter what cycle it is on. It just gives three beeps. No code shows on the display. Is the control panel about to go out? Something else about to break down? Please point us in the right direction. I would prefer to fix it before it dies with a load in it.
Thanks for the help!
I don’t know of any reason why that should be the case. Under the top there should be tech notes that will tell you how to put it into diagnostic mode and maybe that will give you some clue as to what is going on.
Otherwise I have no recommendation other than to keep using it. I do not know of any preventive maintenance that is applicable here.
Be sure and clean out the drain pump and hoses.
