The start button will not activate the washer. It has been wiggling and would start it, but now will not start. Is this something that can be repaired by a do it yourselfer?
Unfortunately you will have to replace the whole part, the start button itself is not sold as a separate part.
Sorry
If your duet washer won’t start its most likely due to a bad part behind the start button.
Here’s how to fix it at home for 35 cents: https://youtu.be/N8rz8sclwAg
