Whirlpool duet washer F22
Folks
I got the dreaded F22 code on my Whirlpool washer. The door does open and closes. I pushed the sensor pin, after about 40 seconds, the code pops up and the washer shuts down. First, i disconnected the washer and after 20 mins, turn it back on and same thing happened. I waited 24 hrs to turn it back on without any luck. I order the latch mechanism (AP3968085) from here and replaced it without luck. I also bought the strike (AP4366423) but never used it because i did the push pin test on the latch. What else can be the problem? I hate to replace the Control
The potential problem other than the door lock mechanism or the control unit is the wiring and connections.
Check all of them beween the door lock and the control unit, and if everything checks out then you are looking at trying the control unit replacement.
If you buy from this site and the part does not fix the problem you can return it, see the returns policy for details. Also, make sure you provide your serial number as they may be more than one version of the control.
How do you change part #AP3968085 Do you have to take the seal off the door oppening to reach behind the front panel?
Someone fliped the little plastic finger up inside the latch and I can’t get it to go back down so I can close the door.
Other then that everything seems to work!!
You have to pull back the seal, but do not take it all the way off. Take off the wire holding the seal on and peal it back enough to get to the door switch.
Thank you got it all up & running..
Great, glad you got it fixed and thanks for the update.
