Replaced the door latch assembly twice now. Any suggestions? I noticed that the door hinge was rather loose, called Whirlpool they said they had “remanufactured” screws that I would have to pay for. What would be the next idea? Boy, could I use some help!
Possible that the door latch does not engaged properly due to a door hinge problem.
Remove the top panel and check the door latch switches for continuity at the CCU with the door locked and unlocked.
