Whirlpool Duet tub replacement
I’m preparing to replace the entire tub assembly and have received replacement parts from Whirlpool. I also have downloaded the service manual (duet_job_aid.pdf) and looked through the relevant sections. I am technically inclined but intimidated by this task; I have nothing to loose since the parts were free under warranty and will replace the machine if I’m not able to replace the tub properly. I was looking for any advice on what to expect or perhaps a ordered list of steps for the procedure. Thanks very much in advance.
-rip
This is a time consuming but fairly easy job. Just follow the instructions in the manual and you should be fine. I will be of great help to have someone help you. Just take your time, go slowly and you should be fine.
Thanks. I was able to compete the replacement and the washer is working fine now.
Hey Ripman, how did you get a free tub from Whirlpool? Was it part of the ten year warranty? What was the problem you were having? I’m asking because my washer makes a lot of noise and the inner basket can be pitched up and down by hand. I’m sure the back bearing is shot! Is this why you replaced yours?? Thanks..
[QUOTE=jgb23;570614]Hey Ripman, how did you get a free tub from Whirlpool? Was it part of the ten year warranty? What was the problem you were having? I’m asking because my washer makes a lot of noise and the inner basket can be pitched up and down by hand. I’m sure the back bearing is shot! Is this why you replaced yours?? Thanks..[/QUOTE]
My tub was under warranty since the machine is 9+ years old. The bearings were shot on the outer tub assembly causing the inner tub to rub against it during anything other than LOW spin speed. I could see the plastic shavings near the rubber boot so I was pretty sure that was the problem. Right before I took the machine apart it started leaking water down from the front door.
