Whirlpool Duet Sport Washer problems
I am getting error codes F 33, F 26 and F 24. I have replaced the door lock assembly and a bad drain pump assembly, checked connections and wires. I have unplugged overnight and still getting the same codes after replacing the items. It will power on, allow me to choose cycle, hit start button and door locks and then it does nothing. It will always go to add a garment every time and will not unlock door. I have to unplug and plug back in to even get it to respond to anything, even a diagnostics test run. I have checked all component tests and all are good per service manual ohm readings. Any ideas of what to do next?
Fixed. I found a solder point on the Motor control board had shorted from moisture and popped the solder away from pin. Could only see it with a jewelers loop. Soldered the one point and put back in and and it runs like a top.
After days of troubleshooting and advice from so called experts, I found, I conquered. Saved myself $600.00 plus.
