Whirlpool Duet Sport displays two dashes (--)
My Duet Sport displays two dashes when selecting the normal, heavy duty, or whitest whites cycles. Attempting to select quick wash lights up the delicates LED. The other cycles show the timer as usual. Thankfully selecting delicates will still wash my clothes.
It was functioning normally last weekend and, as far as I know, nothing has changed since then. I tried unplugging it for awhile hoping it was some sort of computer/controller issue. I ran the diagnostic test once and it stopped after draining and before the final spinning stage. I ran it a second time and it displayed F-01 before anything even started. Interestingly, the “bottom” cycles continue to work.
Any help would be greatly appreciated. I’m guessing it’s that main control board, but it costs way too much for me buy it just for the heck of it.
Edit: model number should be WFW8300SW02.
Edit 2: I left it unplugged overnight and when I plugged it back in this morning, everything seemed back to normal. A couple hours later I go to use it and it’s doing the same thing as yesterday (but still running the delicate cycle right now). I did not attempt to run it this morning to see if it would go through the full Normal cycle. That will be my next experiment.
For the benefit of anyone with the same issue, leaving the washer unplugged until I need to use it lets me select and run the normal cycle. I don’t know how long it needs to be unplugged to “reset” or if it will function normally for more than one load. I just know that it seems to work when I need it and eventually goes back to the two dashes.
