Our Whirlpool Duet washer stopped working in mid-cycle. Now, it beeps 3 times, the “wash” light flashes 1 time , then flashes 9 times. It continuously repeats this pattern. How can I fix this girl?
Look under the top cover or inside the lower service panel for tech notes. They should tell you how to put it into diagnostic mode and interpret error codes.
Thanks. I called for a technician. The dryer is on top of the washer, in a small laundry room, and I am no longer strong like bull.
Ok, sounds like a good idea given your situation. Good luck!
