Whirlpool Duet Front Loader
Hi Our Whirlpool Front Loader Makes A Rattling And Growling Noise And Is Not Spinning.with Lower Cover Off It Sounds Like Something Rolling Around In The Front Drain Pump.i Put It On Another Cycle And It Spun A Couple Of Times And Started To Make The Noises As Before And Not Spin.the Machine Is 9 Years Old,what Part Should I Check To Solve This Problem. Thanks,rick
You always start on this type of problem by taking of the pump and cleaning it out and cleaning out the drain hoses.
