Brand: Whirlpool duet front loader
Model Number: WFW9500tw03
Main Symptom: not draining completely.
Error Code (if any): random f21 f27 which points to drainage issue.
Parts or tests already tried: replace the pump. Tried different circuit board. Remove all drain hoses. They are clear. Blew air through pressure switch hose does not seem to be clog. Wasn’t sure if pressure switch would cause this. Also notice when I do a clean cycle washer will fill up with water and then immediately drain and go through cycle. If I take the drain I’ll cover off after cycle. It’s full of water but washer itself is empty
