Whirlpool Duet F01 Error
Our dryer is displaying an F01 error, from what I have been able to find online it is the control unit; however, I called Whirlpool and they said that there are there control panels, two at the top and one by the motor. Which one needs to be replaced?
Parts for Whirlpool WED9200SQ1 Dryer - AppliancePartsPros.com
See the attached tech sheet for the info you requested (page 9).
Have you tried unplugging the unit for a couple minutes to see if it will clear the error?
Some times a microprocessor can become confused and needs to be manually reset, removing power from it does this.
WED9200.pdf (653.3 KB)
