Hello. I have a whirlpool duet washer that has is giving me a error code FH I had ran the diagnostics and I received code C:05 please help. Thanks everybody.
Hi Ben,
Check the pressure switch as described in the attached file. Male sure the pressure hose connected to the switch is clear.
Testing pressure switch.pdf (130.9 KB)
