Whirlpool Duet Dryer and Error Code F70
Replaced vent hose (and cleaned lint out of inside and exterior vent area) and since then dryer keeps shutting off almost immediately after turning it on. It shows Error Code F70. Dryer seems to have plenty of heat. Have unplugged it several times. Gotten a couple of loads dry in past week, but usually won’t run more than a couple of minutes. Took top off and re plugged in connections. With top off 2 loads dried, then put top back on and quit working again - noticed moist hot air in dryer (outside of drum unit) when took cover off again.
Model wed9200sq0
[QUOTE=bustdwhrpl;553305]Replaced vent hose (and cleaned lint out of inside and exterior vent area) and since then dryer keeps shutting off almost immediately after turning it on. It shows Error Code F70. Dryer seems to have plenty of heat. Have unplugged it several times. Gotten a couple of loads dry in past week, but usually won’t run more than a couple of minutes. Took top off and re plugged in connections. With top off 2 loads dried, then put top back on and quit working again - noticed moist hot air in dryer (outside of drum unit) when took cover off again.
Model #WED9200SQ0[/QUOTE]
Any answers to this question?
Not yet, may someone else
