I was getting the dreaded F2 error and found that the problem is related to a clogged filter or pump problem. I removed the filter (first time in years! and that’s with 4 kids!!!) and it was nasty. I cleaned it out and reinstalled it and ran the Duet through a clean cycle. The pump worked flawlessly.
The problem I have now is that there is a water leak around the pump. The leak is NOT coming from the replaced filter. I screwed it down tight and checked with a dry cloth to see if perhaps the water was coming from there and it’s not. It seems to be coming from the pump itself. Is this unusual? Could I have disturbed something when cleaning the filter? Where should I go from here?
Thanks all!
PalmBayChuck
Chuck@Watersworld.com
