Whirlpool DU1100XTPB3 not working
I have a Whirpool DU1100XTPB3 dishwasher with the “Clean” light blinking and the dishwasher won’t run. The owners manual says the clean light blinking means check the heating circuit. Would this indicate the heating element has failed or would it be in the circuitry?
Parts for Whirlpool DU1100XTPB3 Dishwasher - AppliancePartsPros.com
[COLOR=“Blue”] Would this indicate the heating element has failed or would it be in the circuitry?[/COLOR]
You cannot tell without testing.
Check the heater resistance.
Check the hi-limit thermostat.
Check the door switch, that is closes and is 0 ohms when closed.
Check the wires from the heating element to the control board and to the door switch.
If all OK then it is the control board.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
GU2500.pdf (167.5 KB)
