Dryer dryes fine but does not turn off. The knob stays where you set it when you start it. Changed the timer but that didn’t fix problem.
Would it turn off on the timed dry?
Here is the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGB6000KQ1 | AppliancePartsPros.com
Didn’t try timed operation.
Can you try and post the results?
As your dryer is not turning off, I would contact Whirlpool directly at 1-866-698-2538.
I cleaned the dryer then tried it again. Noticed the burner comes on when you first put the clothes in and turn it on. Then as the clothes start drying the igniter comes on but the burner does not light. Could this be a bad coil on the gas valve? Any sugestions.
Most likely the problem is a bad gas valve coils.
I ordered the gas valve coils hope this fixes the problem.
Keep us posted.
