Whirlpool dryer timer won't stop running
I have a Whirlpool dryer that the timer just keeps running. The only time it turns the timer off, is when the door is open. If you start the dryer, and turn the dial, it will stop when it reaches OFF, but then if you turn it to the next setting, it starts right back up. If you open the door, then close it again, it won’t re-start unless you hit the start button again. It sounds like a relay of some sort is clicking in the console whenever the door is open. I have tested the start button for continuity. It is working correctly ( at least it’s only making a connection when the button is actually depressed). I have swapped motors out also thinking the motor relay might be stuck closed, but after 4 different motors, same result.
If need be, I can upload a picture of the wiring schematic. But, I have included the units model number in this post. Any help would be appreciated!
If you place the timer on “timed dry”, does it advance? If not, you have a bad timer motor or contacts inside the timer are not sending power to the timer motor. If this is the case you will have to replace the timer
I have placed it on timed dry. It spins through the cycle, making heat how it should and the timer is advancing. Then it keeps on going past " off ", to the next cycle, then past " off " again.. Spinning and spinning, dryer still running. Only thing that stops it is when I open the door. Then I can close the door and re-start.
It is definitely the timer. The contacts supplying voltage to the timer motor are stuck together. Make the motor run continuously until you open the door, killing the circuit.
The timer in question can be dismantled if you are very careful and you may be able to clean up the contacts that are sticking or burnt. Be very careful when you take the cover off. I have many used dryer timers in my junk box and sometimes rob internal parts to fix one. It can be done and there is a U tube video showing how to do it.
ok. I was really struck by this, because I got 3 dryers in this week that are all doing it ( all Whirlpools, or built why whirlpool ). I rip Invenys dryer timers apart, all of the time and swap contacts out. I will look in to that tomorrow.
Hello,
I have essentially this exact same problem. I want to make sure I’m fixing the correct part, though.
My dryer will shut off when I open the door, but otherwise the timer advances continuously. When I remove the circuit board, however, it will stop at the end of the regular timed cycle (it does not seem to advance in the accudry cycle without the circuit board). So I’d like to figure out whether it is the timer or the circuit board that has the issue and needs to be replaced.
I should mention this all started after the dryer had a power short and there was a bit of spark/fire near the timer. I would assume this means the timer has the issue, but assuming can also get you in trouble.
Any help would be appreciated.
Thanks!
David
Having similar issue . The timer continuously runs . It will shut off when it reaches off but then continue and turn on the next cycle .
You need a new timer assembly. As I stated in a previous response one or more sets of contacts are burned or damaged. Sometimes you can clean them if you are very careful and can take the timer apart. Dont expect it to work properly as it may be beyond repair. Also look at the small gear on the end of the timer motor shaft . If it is worn badly you will need to replace the timer.
If you are still trying to get this dryer to work properly and need a timer I have several used ones and I can provide one from a Maytag dryer . the timer works OK but the motor is worn out. Advise if you want it for the price of postage. I live in Washington, Illinois with zip code 61571. Let me know ASAP otherwise I will be scrapping this unit. My e-mail is as follows
jaybird@mtco.com
I have several timers that I can provide one for the price of postage. One of these also has a small bell to announce that a load is done . I have the schematic page for this dryer also and can take a picture of the item if that would be helpful . Tom H
Wpl dryer m# lte6234dt3 runs constantly even with a ew timer
I just created a new thread and then found this one. I have a Kenmore 110.62802 (made by Whirlpool) with the same issue. It stops at the end of the cycle, but the timer continues to run until it starts the next cycle. If I turn the timer, the machine starts whenever it enters a cycle (without pressing the start button). The only time the timer stops is when the door is open. I’ve tried two new timers and both have done the same thing. Just ordered a new start switch. If that isn’t it, I’m not sure what to try next. Any ideas?
Hey Mike39177, have you got the starter switch? I am having the same issue. I noticed when I disconnect the start switch the timer stops spinning. I had the back cover off of the dryer and on the timer you can actually see it spin when there’s power applied. I am guessing something shorted inside the starter switch and is constantly sending power to the timer. I am looking one up to order but started reading around and wanted to see what other people had come up with.
I responded to the email I got about your comment, but just noticed today that it said to log back onto the forum to respond. Sorry about that. The switch came in today, and thankfully it did fix the problem. I had the same suspicion you did, that it had a short and was constantly sending power to the timer, and it turns out we were correct. :grin:
I ended up replacing mine as well and it did fix the problem. I’m glad we were both able to resolve our issues with the same fix! Thanks for reaching out!
I have a Whirlpool dryer in which the timer didn’t advance at all.
I replaced all the thermostats and that didnt fix the timer at all.
I finally switched out the timer, and now it will advance but will not shut-off after the cool-down phase.
I put my hand behind the vent and noticed that it was still producing heat while in the cool-down phase.
I replaced the heating element and now everything works like a charm.
My old heating element, part of the heating coil snapped and wasn’t making a full connection, while the inside metal bracket of the heating element curved outwards making the broken elements to touch the metal frame of the heating element.
In my case, I had a bad timer and a bad heating element.
Point being, one could have a perfectly good timer if the timer isn’t advancing to the off position and that the culprit just may be a bad heating element.
