I’ve got a whirlpool dyer that was working fine and now it will not start. Here is all the information I have on it.
MOD # LER4634PQ0 SER # MSO412623 TYPE D433-ELE-2406028-FM54
I’m wondering if the push button switch might have failed possible. I took the back covers off everything and could not find any loose or damaged wiring. Is there any known issues that this dyer might have with this type of thing? I apprecaite any help that you can provide to help me get this thing working again. I’ve got some laundry I’ve got to do and I hate to go to the laudry mat if I don’t have too. LOL!!
A common cause of this is the thermal fuse on the blower wheel (Item 19 in Section 3) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Thanks for getting back to me on this. I appreciate it.
I took the two light blue wires that were on the fuse and tapped them together and it still wouldn’t work. I tested the fuse as well and it gave me a reading of .5 or .6 if I remember correctly. Is there anything else I could try? Could the switch on the dash board be the problem?
Thanks in advance for any other help you can provide.
If it has an interior light, does that work?
OR
Check the power between Neutral and L1, should be 120 volts.
Other things to check are the door switch and the push to start switch.
Then the BK/BU contacts on the timer.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
